Where do I find VISA Driver Develper Wizard
I would like to create an .INF file for a custom USB device. I tried to follow the instructions from the "Using NI-VISA 3.0 to Control Your USB Device" document but I don't see VISA Driver Develper Wizard installed on my PC. I use NI-DAQ 7.3 and I have VISA 3.1 but no VISA DDW.
Do I need to purchase it separately or is it distributed only with NI USB devices?
Thank you,
Radek Uberna
(3,335 Views)
Radek,
The VISA Driver Development Wizard is installed with NI-VISA, so it sounds like it should be available.  It is located on the Start menu at Programs » National Instruments » VISA » VISA Driver Development Wizard.  If for some reason it is not at that location, you may consider upgrading to the latest version of VISA, which can be found on the Drivers and Updates page.  Hope this helps, have a good day!
(3,322 Views)
