Where do I find a driver to connect Chroma 6310 connected through USB?
I have a Chroma 6310 Load connected by USB. It shows up as a USB Test and Measurement Device (IVI) The Agilent driver AUSBTMC causes a blue screen of death. I have tried to locate the NIUSBTMC driver, but have failed. Where can I find a windows driver so that my Chroma load will be available through MAX, and NI VISA?
I have downloaded and installed NI VISA and the NI Labview trial latest versions.
Luke
(5,030 Views)
Luke,
Here is a link to the NI certified driver for this device.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1138
This should resolve your issue.
Pete
Peter C.
(5,016 Views)
Thanks for the infromation, I downloaded these and did not find a USB driver in these files. Until I get the device connected through USB, the labview files will not help me.
(5,011 Views)
Accepted by topic author faeluke
I don't think ausbtmc has anything to do with Agilent. In any case, see this discussion.
(5,009 Views)
My mistake Luke,
I couldn't find any drivers for the USB interface in our list of drivers, but I did find something on the Chroma website.
http://www.chromaate.com/driver/default.aspx
It seems the 6310A drivers have USB support.  Have you tried those?
Peter C.
(5,002 Views)
The thread you suggested contained the answer. The driver can be found here:
The device is recognized now recognized by MAX.
http://ivifoundation.org/shared_components/Default​.aspx
I appreciate the help.
(4,977 Views)
