Where do I find a manual on IVI interop ?
I'm currently assigned to work on a application which uses IVI interop functionallity
and I'm facing some issues with  Ivi.ConfigServer.Interop.IviConfigStoreClass not being able
to find the resources I know is in the parsed file.
Is there anyway to retrieve the manuals for this without installing the compilance package ?
Br Thomas
(4,642 Views)
Hi Br Thomas,
Can you please explain in more details what exactly you are trying to do? Do you use IVI-C or IVI-COM technology?
Vesna Jadric
(4,626 Views)
Dear Vesna,
IVI Com to .NET.
I'm using an application which tries to extract driver information from a logical name using the
Ivi.ConfigServer.Interop system.
myConfigStore = new Config() //Class which includes public IviConfigStore ConfigStore { get; }
IIviDriverSession session1 = myConfigStore.ConfigStore.DriverSessions[sessionName];
My problem is that I do not have any help file or documentation on IVI,
So do you know if there is any way to get the help file or the documentation without installing
the compilance package ? (if that's where NI includes this)
Best Regards Thomas
(4,610 Views)
http://www.ivifoundation.org/ is the repository of all things IVI. this is especially true for IVI-Com as the drivers written by NI are IVI-C. You might also check the vendor of the IVI-Com driver.
(4,602 Views)
Hi Thomas,
Dennis is right - National Instruments develops and supports only IVI-C drivers so the manual or any other information about the Interop functionality will not be in the IVI Compliance Package. My suggestion would also be to contact the IVI Foundation for support.
Best Regards,
Vesna
(4,598 Views)
Thomas,
I think what you are looking for is documentation for the IVI Configuration Server COM API. You can find this in the IVI-3.5 Configuration Server specification. You can download it here: http://www.ivifoundation.org/Downloads/Architecture%20Specifications/IVI-%203.5_ConfigurationServer_...
Hope this helps,
z_haider
(4,592 Views)
The document was exactly what I needed to fix my problems !!
Thanks alot  !!
Br Thomas
(4,567 Views)
