While Loops and SubVi
I tried to use a while loop in a subvi. I wired the conditional to the main vi throght the connector panel,but had problems. Is it possible to use a while loop in a subvi?
(3,198 Views)
Hyatt,
You may have better luck getting an answer to this if you post to the LabVIEW General forum.
However the reason this is not working is that when you call a SubVI the values from a Main VI are passed 1 time. Therefore you can not change the SubVIs stop terminal from the Main VI, by passing the boolean. You could do it with globals or passing by refernce.
(3,198 Views)
