Who can I define for an executable application the com-ports for VISA controlls?
I want to use an executable version of my application on a pc, where LabVIEW is not installed. I defined the values of my VISA controlls with MAX, leading to the standard names "Com1" and "Com2" for the seriell ports.
But on the pc, where I want to use the application, the standard names are not recognized, leading to an error.
What can I do?
Thanks for your help!
(4,146 Views)
Don't use the VISA alias in this case. Use the actual VISA resource names which are:
ASRL1::INSTR = COM1
ASRL2::INSTR = COM2
This should work on any computer. Make sure of course that the computer has VISA installed.
(4,146 Views)
Thanks, but this leads to 2 new questions (which I try to write this time without a stupid mistake like who instead of how 😉
1.) Does installing VISA on another pc require a licence of LabVIEW? Can the installation of VISA be combined with the installation of the executable?
2.) How can I remove the changes in LabVIEW, that MAX did for defining the com names without uninstalling MAX?
(4,146 Views)
1) there was recently discussion of exactly this issue here on the forum at this location http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000BB2A000...
2)I don't think you have to redefine the names, VISA is supposed to recognize both aliases and resource names. I just tested the viOpen command and it returns proper results with both "COM1" and "ASRL1::INSTR". so if you just change t
he string you pass to viOpen everything should work fine.
(4,146 Views)
Thanks!
It seems to exactly what I searched for!
(4,146 Views)
your links were very useful and some of my problems are solved. But the automatic installation of the VISA-driver doesn't work. I'm using LabVIEW6.1 with VISA2.6. I have included all files of the NI-visa directory of the LabVIEW-CD as support files in my application and inserted the setup-file "NIvisa26.msi" as executable in installer settings/advanced.
When I install my application, the following error message is displayed:
"Internal error 2743. NI_CA_EXE,
(installpath)\data\NIvisa26.msi"
I didn't found the error in the knowledge base.
Another problem is, that all install files (NIvisa26.msi and the required *.cab files) are copied to the data directory of my application. If the installation would work, I had to delete this files "per
hand", which is a little bit stupid for an "automatic installation".
Though my questions are:
1.) What is the problem with the internal error?
2.) How can I install the VISA-driver without copying the install files in the data directory?
(4,146 Views)
