I am running LabView 6.1 on windows 95. Up till now I have had no problems. However, we recently acquired a Temperature / Humidity probe which plugs into the Com1 port of the computer and logs the data using it's own software. Since then, when the two programs are used together, eventually LabView crashes with the following error message: Failure, 'image.cpp, line 5793.
Can you tell me why this occurs and what the solution is?
