Why does gpib-32.dll crash after upgrading to NI-VISA version 2.5 from 1.7?
We are using GPIB-PCI card and it came with the ancient CD "NI GPIB 488" driver version 1.7.  The measurement and automation version is 1.7.  We specifically use the "gpib-32.dll" to do your basic ibwrt, ibonl, GPIB communication in Visual Basic 6.
Once I immediately upgraded to NI VISA 488 version 2.5 CD, our program crashes saying that a problem occured with gpib-32.dll ??  When we reverted back to version 1.7, all was okay in Visual Basic 6.  The new CD version 2.5 also came along with our hardware GPIB-PCI card.
So can someone tell us why the software is crashing with gpib-32.dll ?  When we tried to replace teh gpib-32.dll from version 1.7, this also did not solve the problem.
(3,494 Views)
NI-VISA has nothing to do with this. There is no version 2.5 of NI-VISA. It is NI-488.2 that you are trying to install and the latest version is 2.7.3. Version 2.5 has not been "new" for a while.
I would suggest a complete uninstall of the old version first instead of trying an update. Then, test communication with the instruments in MAX.
(3,489 Views)
If you are making direct calls into the gpib-32.dll, the functions in the dll may have changed from 1.7 to version 2.5.  I would recommend stepping through your program...finding the exact NI-488.2 calls that are causing the problem and then you should see if the function was depricated or changed.
Also, since you are upgrading your driver, you should re-compile your program with the new driver.
Steven T.
(3,431 Views)
