It sounds like the instrument is setting itself up as the system controller.
Are you calling ibrsc to attain system control?
What is the make and model of this device?
If you are using a different gpib cable when you connect to the one device try using another, it could be a broken cable.
Are you able to communicate via
IBIC? If not, what command fails.
Ray Kong
NI Applications Engineer
