Why does the NI-Fgen ver1.01 installation not install the example programs for msvc?
The installation is successful but the entire examples directory is missing, is there anywhere on the site where I can download these examples?
(3,980 Views)
erict,
If you selected Visual C++ as a programming environment during the NI-FGEN installation procedure, you should have the examples listed in c:\VXIpnp\win95\NIFGEN\examples\MSVC. If you are using Windows NT or Windows 2000, this directory will be c:\VXIpnp\winNT\NIFGEN\examples\MSVC. If the examples are not listed here, you can re-install NI-FGEN and select Microsoft Visual C++. NI-FGEN can be downloaded from the web at http://www.ni.com -> downloads -> drivers and updates -> current software versions -> NI-FGEN.
Jace
(3,980 Views)
Jace C,
Thanks for answering, unfortunately I had tried all of the options mentioned and the installation still did not open an examples directory. Do you have any other ideas as to what may be the problem?
(3,980 Views)
erict,
The examples for Microsoft Visual C are now posted at ftp://ftp.ni.com/incoming/FGEN_Examples.zip
This is not a permanent place for the examples. Please contact National Instruments if you need these examples again in the future.
Jace Curtis
NI Applications Engineering
(3,980 Views)
