Why does the application built executable run slower than my developement lib.
The Response given was LabView 5.0.1.f1 specific. Iam however, using LabView 6.i. The Application runs approximatley 3 to 40 times slower than the developement library. Additionally the Write to spreadsheet data is corrupted when using the application executable. Is there a different solution for 6.i ????
Tnx
Len Kraus
(3,286 Views)
That does not sound right. I recommend rebuilding your VI. Beore you do, open the top level VI and press contol-shift-run arrow to perform a manual binary recompile. This makes LabVIEW recompile the whole code. Most times you will not see anything happen but occasionally an error will surface. Be sure to save the VI then rebuild it.
You may also need to reinstall the LabVIEW run time engine and/or LabVIEW. I would start with the run time engine first.
(3,286 Views)
