04-22-2009 03:43 PM
04-23-2009 03:00 PM
04-23-2009 03:34 PM
Hi Swint,
The driver will work independent of MAX; there is no need to configure the scope in MAX at all. In the example VIs, enter VICP::<ip address> for the resource string when configuring scope to use the TCP/IP interface. What happens when you do this? Do you get an error?
(Unless the MAX issue is a NI-VISA issue................. )
Cheers,
Alan
04-23-2009 03:43 PM
Hmm... I was actually trying to use the LXI interface, rather than the VICP. Looking on the scope's web server, I copied the address "TCPIP0::193.195.1.2" and put it in as the VISA resource name in Labview. I get a beep from the scope (the sound of scientific progress) and then
"Error -1074000000 occurred at an unidentified location"
"Possible reason(s):
LCWAVE Error Query;
instrument reports:
Unresolved parsing error."
(Wow! An error box from which I can actually cut'n'paste the message! Thanks NI!)
I'll try setting up the scope to use VCIP.
04-23-2009 03:45 PM
OK, if I change to VICP, the error message changes:
"Error 85 occurred at lcwave Read Command Error.vi"
Scan From String (arg 1) in lcwave Read Command Error.vi->lcwave Error Query.vi->lcwave Initialize.vi->lcwave Acquire and Read MyMeasurements.vi
The format of the CMR? response is not as expected. Make sure that the Command Header is not being reprogrammed from the value configured in the Default Instrument Setup VI, where it is configured to OFF with the command CHDR OFF. (Default Instrument Setup.VI is called from Initialize.vi.)
Complete call chain:
lcwave Acquire and Read MyMeasurements.vi"
04-23-2009 03:51 PM
OK, the Error 85 occurred with "TCPIP0::..." If I change the resource name to "VICP::..." AND the scope is on TCPIP(VICP) I get the Error -1074000000.
The error log on the scope shows errors from the AS Interpreter,
"error: command < VBS app.Measure.MeasureSet=0 : .app.Measure.ShowMeasure=TRUE : .app.Measure.StatsOn=TRUE : .a...Measure.HistoOn=False> at to"
with either the VICP or the VX11 control.
04-23-2009 04:01 PM
So the scope is definitely receiving commands... With VICP, what happens when you try to run the Transfer Selected Waveform VI after manually acquiring a sweep on the scope?
For LXI, the VISA Resource String is formatted TCPIP0::<ip address>::inst0::INSTR. (You can find this out by going to the scope's IP address from your web browser; a web interface is required by the LXI spec.) I find that the LXI interface might not work right after rebooting (it needs to be reset) so if you have problems, don't spend too much time using LXI for now.
Best Regards,
Alan
04-23-2009 04:14 PM
04-23-2009 04:17 PM
04-23-2009 04:18 PM
Hi Swint,
Make sure that your program is running the Initialize first... If you are doing this, please email me your VI and I'll give it a look.
Best Regards,
Alan
