Why it's take a while to get a TCP Connection
I Guys
I open VISA Interactive Control
and I see my USB Connection just in time,
but the TCP/IP Connection takes at least 5 min to be recognized.
What is the reason for this and can I force the auto detection?
I Develop an Application in Delphi
(4,599 Views)
Can you give us a few more details about your hardware setup please?
- which device are you using?
- is the device directly connected to your computer or part of a bigger network?
And do you only see this behavior in the VISA Interactive Control or also in your application?
Best regards
Christian
Christian
CLA, CTA, CLED
(4,553 Views)
Sorry
It's a direct TCPIP connection via a switch
192.168.1.200 - 255.255.255.0
If my Rigol DS1074Z is on and I start my PC
I don't have a delay, but if I power on My DS1074Z
it takes a while.
The USB Connection is just in time available.
In Pascal
viOpenDefaultRM(defrm);
Error := viFindRsrc(defrm, '?*?', list, nmatches, matches);  // Open the device
if Error <> VI_SUCCESS then begin
end;
(4,528 Views)
Anyway what I figured out.
If I first start the DS1074Z then the PC
all the other VISA32 function work well so far.
Sometimes I had VI_ERROR_TMO,
when I first started the PC.
(4,509 Views)
