Why to use "IrDA Open Connection" in Labview 6.1
I want to establish a communication between my mobile(NOKIA 5210) with IrDA.
I can find my mobile with "IrDA Discover", but I want to write some GSM command to 5210, I often fail at "IrDA Open Connection", Who can give me some help?
(3,578 Views)
Hello Boone,
Do you have the correct "service name" for your device wired into IrDA Open Connection? I would assume that placing an invalid service name would cause the Open to fail. I'm also not sure what service names would be available on your particular device; that is up the the specific device's implementation.
This link could help you with the basics of IrDA communication: http://zone.ni.com/devzone/conceptd.nsf/webmain/79F65241EDB4F7C586256AB6006703CB?opendocument
Sounds like an interesting application, though, keep us posted.
Scott B.
(3,578 Views)
Hi Scottie:
At first thanks for you repay my question. I think "Service Name" is the key, I've use the Device name(Read from "IrDA Discover").
Boone
(3,578 Views)
