Windows lockup with multiple processes performing viOut16/viIn16 operations
Have a system with 4 VXI chassis, all 4 use VXI-MXI-2 slot zero controllers and control PC uses a single PCI-MXI-2 card.  The MXI-2 bus is daisy chained between the 4 chassis to the PCI-MXI-2 card.  Control PC runs Windows 7 (32-bit) and has NI-VISA 5.4 installed.  Currently have two separate applications/processes that both run at the same time.  One process creates viSessions with instruments in 3 of the chassis, the other creates viSessions with instruments in the 4th chassis.  viSessions to resources are mutually exclusive between the two processes but both interface through the same PCI-MXI-2 card.
The problem we've noticed is when both processes are performing several viOut16s/viIn16s, Windows will lockup (no display updates, cursor doesn't move) and the computer will reset a few minutes later.  There is no current synchronization between processes - our first guess is to try to some kind of shared (interprocess) mutex but this will be difficult to implement due to the complexity of the applications.
Question is: Assuming the lockup is due to contention at the PCI-MXI-2 interface, is there any other way to ensure the two processes don't have 'collisions' when accessing the MXI-2 bus?
(867 Views)
Can answer my own question.  Created a global mutex (Windows CreateMutex) and waited/released around viOut16/viIn16 calls in both processes.  This fixed the problem for us
(843 Views)
