WindowsXP support for GPIG%2FPCI%2FDOS
Hi Corey,
 Here are the two files in .txt format . I can't undestand how the files were empty as I printed them locally before saving them!!.
These files are from a "srart over" system, WIN-XP and NI 3.12 program re-installed. I re-formatted the drive and started over, results are identical in all respects. Not much of a hassle as the only things on XP are the NI and a HP printer program and wireless net access card. I just wanted to be sure the installs were not corrupted.
Is there something  in the way i have written the instrument control programs or compiled them? DOS 6.22, MS -QB45 and compiled from DOS command line.
Ted
Message 11 of 27
(4,952 Views)
HI Corey,
Did the .txt files I sent arrive OK and are openable??  Any other test thast I can run to assist?
Do you know how to make that very short informational dosbox screen about the National Iinstruments DOS handler slow down or stop so I can read it?
Ted.
Message 12 of 27
(4,933 Views)
Hey Ted,
I've taken a look at your trace files. It appears that you have a timeout on the read function, which occurs after you write to a certain device.
The device info that is timing out is:
Is it possible to increase the time before a timeout is determined for this device?
Message 13 of 27
(4,917 Views)
Hi Corey,
 Those two timeouts  are irrelevant, they are a result of my input errors. The plotter is what I call a "DUMB" instrument.
In order to obtain any response from this plotter you must first write to it an explicit specification for the status information you expect to receive upon requesting a read, this loads internal the read buffer with this information . Failure to do this always results in a timeout as shown regardless of the timeout setting as the read buffer is empty.  Note that there is no such write requesting the plotters status prior to the read,  just  pen change instructions, my error in not specifing what status ingormation I wanted by a executing a write for status informatiom, prior to calling for the read.
Ted.
Message 14 of 27
(4,915 Views)
Ted,
I'm working on this issue with some other engineers. I'll post when I have more information.
Message 15 of 27
(4,892 Views)
Hi Corey,
 OK , thanks for the update. I have gone back to running the old PIII with DOS on an AT-GPIB board for now.
Any further information you need from me??  I await your post..
Ted.
Message 16 of 27
(4,889 Views)
Hi Corey,
 What progress have you managed to make with this problem I have?? I have been trying to make this work and have conclufed ( possobly wrongly) that there is some disconnect between the DOS BOX part and the GPIB part. I went through the file ( per NI documentation) requirments again and have not found any errors.The programs start in the DOS BOX just fine until there is a call to the GPIB part, then fail. I can send you some more NI trace files if you want, but the programs always fail at exactly the same point as the ones i have already sent to you.
Programs coninue to run OK in DOS and Win98 with  AT-GPIB cards  on the PIII & P2.
Ted..
Message 17 of 27
(4,858 Views)
Ted,
Sorry for the late reply. More NI trace files would be helpful. I'm still working with the GPIB GO-TO's here...
Message 18 of 27
(4,848 Views)
Hi Corey,
 Please excuse my delay in providing more NI trace files as requested, I have been busy.  Attached are  two files:
Capture.nitrace is the information obtained when running the Tek. 495P spectrum analyzer and the HP pen plotter which both dance to my tune without error as long as I do not make any input errors. The last information from the SA is the beginning of a 12.8 KB screen plot file that is of course incomplete.  I find that I can also make other instruments behave similarly in this enviromentSmiley Happy
Capture1.nitrace is the information when I run a DOS/QB45 based .exe file  ( compiled under DOS which executes perfectly in a DOS enviroment with an  AT-GPIB PNP board) and uses only the same instruments as above, the SA and pen plotter.Smiley Sad
I have been working at this end to try and resolve this issue without success, but have found that the failure seems to always occur when a CALL is made. I have set up the  XP  C:\  drive so that it has on it the files associated with the GPIB system in the same structure as on the C:\  drive  of the computer running the DOS files except for the driver files for the AT-GPIB board  which can not be used as the board does not exist in this system.
Question ( for some programming expert )  can I run QB45 from within the DOS box successfully?? If this is possible I can
run the failing program(s) step by step ( in basic)   and determine  the step that is the cause of the failure. A more succinct question is I think,  is the DOS BOX a perfect DOS emulator??
Ted.
Message 19 of 27
(4,831 Views)
Hi Corey,
 I forgot you wanted the trace files intext so here they are, I hope !!!
Ted
Message 20 of 27
(4,826 Views)
