Would it be possible to get an end of life expectancy for the NAT7210?
We are working on a design that will likely use either a NAT7210 or a NAT9914 GPIB controller and want to make sure that the device will not be going obsolete any time soon.
Would it be possible to get an end-of-life expectancy on these parts?
Thank you.
(3,150 Views)
Hi Jeff,
You should directly contact NI Support.  You can reach an engineer who can help you with this issue by emailing or calling from the Request Support page.
Thanks!
Meghan
(3,132 Views)
