Write commands to GPIB with precise timing
I would like to write a command to the GPIB card several times, the time interval between two writings must be very precise(<1ms). This time interval includes two parts, one is the time GPIB communicates with the instrument, another is the software delay time.Both are not precise enough.My idea is to hardware delay a time interval and at the begining of the delay, write a command to GPIB simultaneously.So the time GPIB communicates with the instrument is covered by the precise hardware delayed time.I wonder whether this is possible.Any ideas??
Thank you for your help.
(3,630 Views)
I'm still not sure that I understand. You want to delay a command on the GPIB bus?
If you are working in a Windoze environment, you can not be that accurate. Windoze does not guarantee any timing within 100ms. Using my NT box, I can get my timing down to around 4ms accuracy. The problem is the way that Windoze handles its multi-tasking and background tasks.
Rob
(3,630 Views)
Hi cooler
I had the same problem with you for my application before. That is the limitation of LabVIEW for Windows. I think you need LabVIEW RT for this requirement.
Bill.
(3,630 Views)
