Writing different measurments to a PIC
Frankly, no. What version of the numerous ones you have posted, did you modify to use constants? Did you look at the string being generated with that and compare it to the string when you pass from the amp-freq? Turn on hex or \ Codes Display to see if there are hidden characters.
Message 11 of 12
(1,788 Views)
Okay i got it to work now but there is a hidden character after the voltage its a "\s" then the number. How would you remove hidden characters so it doesnt interfer with recieving the data. You can see in the image below.
Message 12 of 12
(1,781 Views)
