Writing input/output parameters to file
I am using Sorensen's power supply and I have downloaded the drivers for the same from NI's website (DCSM9C) to communicate with computer using a GPIB card. The instrument driver has several sub-Vi's in it and I am not able to figure out which Vi I need to modify in order to write the input/ouput parameters to an excel sheet.
If anyone is or has used this product or a similar application, some help would be appreciated.
D
(3,099 Views)
dbansal,
IMHO it is not a good idea to change a driver, because:
* A good driver is tested and released. Any changes remove this status and require a new testing and release procedure.
* Not all drivers are fully documented for their internal workflow. Changing some internals may break this workflow or introduce bugs.
* It will probably require _some_ extra time to understand the existing driver.
Add your functionality into a wrapper to the existing driver instaed. Put its main into a new BD and copy all of its  controls and displays to your wrapper's FP. Connect 'em.. Create a while with shift registers or even better a state machine that keeps the actual state of the called driver and saves/reads this state to/from your external file (in your case your excel sheet). You may either add a new control that allows to save the existing state, do this saving after each successfull call to the existing driver or whatever rule you need and implement.
Jusdt my Euro 0.02...
Greetings from Germany!<br>-- <br>Uwe
(3,093 Views)
