XNET LIN Max Schedules
Hi all,
I was able to set up some hardware so that I could actually run the LIN software.  I am still unable to reproduce the error.   I modified the LIN loopback test example to attempt creating "too many schedules."  The code creates a cluster in memory, and then create a lin frame and schedule for that cluster.  I have created up to 256 clusters without getting an error using identifiers 0-63.  If setting up your interface differently let me know and I can try to replicate the error, or if either of you have your code I could use that to modify my example
Ryan
Message 11 of 17
(1,750 Views)
I wasn't creating clusters. I was creating additional LIN schedules for the same cluster.
Message 12 of 17
(1,749 Views)
Ok,
I have been able to reproduce the error, but not using the read function.  My error pops up when I create my session.  I also have not been able to isolate or figure out exactly when the error comes and goes.  I will work tomorrow to try to isolate what exactly is causing it.  I have also noticed that I have to reset my bus to clear the error.  Did either of you experience similar behavior?
Ryan
Message 13 of 17
(1,733 Views)
When I was getting the error I was using VeriStand so the system was just failing to deploy and I didn't get to see what exactly were the effects of the error. But sounds like the same error.
Message 14 of 17
(1,730 Views)
Ok, so one more question as I continue to narrow down the situation.  What type of session where you using in your applications?  Was it frame out single point, or frame out queued?
Message 15 of 17
(1,724 Views)
I'm using frame out single point, frame in single point, signal out single point, and frame in stream.
Message 16 of 17
(1,722 Views)
I will build this into my code tomorrow and see how if I can reproduce the error for this purpose
Message 17 of 17
(1,714 Views)
