Xantrex XDC Power supply
I'm having issues remotely controlling a Xantrex XDC power supply.  The power supply is connected to the computer through a USB/RS-232 converter, which goes through a powered, isolated USB hub.
I've tried both drivers for the XDC power supply located on the NI website, and I've udated IVI.
The error I'm getting is:
Error -1073807339 occurred
 Possible reason(s):
Driver Status:  (Hex 0xBFFF0015) Primary Error:(Hex 0xBFFF0015) Timeout expired before operation completed
Any ideas on how I can fix this?
(4,019 Views)
There are many possibilites with RS-232. What's very common is that there is nothing to read because the instrument has not recieved the command correctly. Why that could happen is that there is a mismatch between the com settings, an incorrect serial cable, or the command is not terminated correctly. Before doing anything in LabVIEW, I would recomend you first verify communication with a terminal emulation program such as Hyperterminal. Double check the manual for com settings and the cable. Use a continuity check to see what type of cable you actually have. If the instrument has a command such as *IDN?, just keep using that. One adavantage of using Hyperterminal is that vendor should be very familiar with that and you can normally get troubleshooting help.
(4,017 Views)
Check your port settings first is the baud rate right?  Also check your RS232 cabling!  is the Xantrex expecting a straight or a null modem cable
(4,012 Views)
