Yokogawa DL7440 USB driver
Does your DL7440 has another interface. I use DL scopes with GPIB and Ethernet and that works fine.
When I find the time I will try my DL1740 with USB but this might take a while....Smiley Wink
Message 11 of 29
(2,166 Views)
Hi
it does have a gpib port and a usb one. Thats it. The Version i have got is without a ethernet connection.
Message 12 of 29
(2,165 Views)
And thanks a lot for taking the time for trying the usb port
Message 13 of 29
(2,163 Views)
But, let me guess, you don't have a GPIB interface on your computer ?
Message 14 of 29
(2,161 Views)
No not realy.
Well I already suggest my supervisor to get a GPIB to USB cable cause i hope that this works. But the thing is that i am in New Zealand and the guys from the electrical engineering department said they dont have this sort of thing. And to buy one is quite expenisve. Round about 1000 NZ $. 😞
Do you reckon its better to use the gpib port rather then USB?
Message 15 of 29
(2,159 Views)
Yes, it is a lot of money for just one interface for one instrument.
I use the DL together with other instruments, so this is easier with GPIB. btw. is you have a test-setup with 10 instruments like I have you pay twice this amount. Good cable are also expensive.
For one instrument I don't think GPIB is better than USB but it depends on your use.
Message 16 of 29
(2,157 Views)
@ KC: Hi
I some how think it works now. But not sure, there are still a lot of error messages coming up but i keep trying.
For example I used the getting started.vi. After I change all Visa Classes from Instr to USB RAW the big Arrow on the upper left corner turned from broken and grey into a white one. But sitll it wouldn't measure things.
You said you use a Yokogawa device ,too. Can I ask you a few questions regarding the commands used in Lab View?
Kind regards
Message 17 of 29
(2,125 Views)
You can always ask and sometimes you will get the answers   Smiley Wink
Message 18 of 29
(2,114 Views)
Hi
Thanks, i will ask some on Monday cause I am not at Uni at the weekend.:)
Message 19 of 29
(2,088 Views)
Hi
It somehow works now. I just had to change the visa instrument class to USB Raw since Intr is the default value.
But if I use the readmeasure.vi which should measure a signal it only replys NaN. I figured out that it means not a number.
and it uses the command meas:chan1:ptop:val?
I guess it has to do something with the format but i don't know how to change it. Can you help me?
Message 20 of 29
(2,061 Views)
