Yokogawa WT300 Series Meter LabView THD Values
I currently have a LabView program that reads current, voltage, power, etc. off of the Yokogawa WT310 power meters and saves it in a .txt file. However, I cannot seem to get the THD (A %) value from the power meters through LabView. Any help/advice would be appreciated!
(1,597 Views)
The driver package of this instrument contains a VI for setting and reading the Harmonics.
Beside that the Harmonic commands are describe in the manual.
Are you using the driver and the manual ?? Show the program you are using.
Kees
(1,553 Views)
Hi, I'm using the instrument driver but can't seem to find the manual.
I'm trying to get the correct THD (A %) as displayed on the Yokogawa meter using frequency and current measurements, but my methodology is probably wrong. Thanks!
(1,534 Views)
The manual. Maybe this helps.
Kees
(1,523 Views)
Hai,,
Could you share the LabVIEW program that reads current & voltage  of the Yokogawa WT310 Meter.
(1,072 Views)
