a VI for the SR844 lock-in amplifier?
I'm looking for a VI to control a lock-in amplifier from Stanford Research
Systems with LabView. If anyone has one they could send me, or for the SR830,
i would appreciate it very much. I'm also just learning labview, so if anyone
has any tips for using labview with the SR844 they would definitely help.
(5,940 Views)
You should go to NI's web site (www.ni.com) under support and search the
instrument driver database. There are several VIs for SR products. I did not
see any for the 844 but there is one for the 830.
You can get the drivers for a similar instrument and possibly modifiy them for
the 844.
Most vendors use similar drivers for similar instruments.
Kevin Kent
(5,940 Views)
