a combination between the ni488 library and system calls on debian 3.1 (sarge) causes segmentation fault
First of all, I know that the ni488.2 gpib library does not officially have support for debian. However, I tried my luck to see if it would actually work under Debian 3.1 (sarge) and it generally does -  except for one problem which can be illustrated with this short example:
#include <stdio.h>
#include <stdlib.h>
#include <ni488.h>
int main(void){
  SendIFC(0);
  system("ls");
return 0;
I am using a pci gpib card.
Compiled with: gcc-3.4 test.c -lgpibapi -o test.o
Executing ./test.o multiple times will result in either a successful system call to ls and the content of the working directory displayed or a segmentation fault - it seems to fail more times than it succeeds.
Then my question is whether you have seen this problem before?  And if there exist a general solution to the problem. I have found an ugly work-around to put the gpib card offline before the system call (ibonl(0,0)) and then online again afterwards. In  that case the problem does not occur.
I hope you have some suggestions for a solution.
Best regards
M.Sc.EE. Michael Skipper Andersen
Department of Antennas and Propogation
Institute of Electronic Systems
Aalborg University
Denmark
(3,131 Views)
We have had some problems with the fork() command and an active NI-488.2 driver that are probably related to your issue.  I believe the system() call makes a fork() call to start the shell.  Unfortunately, at this time, there is no workaround other than avoiding fork-like calls or, as you discovered, being careful with the state of the GPIB driver as you perform the fork-like call.  Since system() probably ends the child process after it is done, I think that you're probably safe to continue using the NI-488.2 driver after the system() call.  If this were a fork() call, you may have issues making GPIB calls from the child process.
I hope to get this fixed in the next version of the NI-488.2 for Linux driver.  Unfortunately, I cannot provide a timeline for the next version.
Scott B.
GPIB Software
(3,118 Views)
