01-11-2008 07:43 PM
01-14-2008
05:17 PM
- last edited on
11-08-2024
05:40 PM
by
Content Cleaner
Hi Odd_Modem,
This is quite the laundry list of questions.
Here are some good Developer Zone articles to get you going with IVI.
DevZone: Using IVI drivers to Build Hardware -Independent Test Systems with LabVIEW
DevZone: Creating or Modifying IVI Class Simulation Drivers
1. NI is currently using Compliance package 3.5
2. Adding new apps should not be too hard as long as they not running at the same time as other programs, you can run into communication errors with this.
3. Just like any other DLL, make sure they are in the right place when you call them. A lot of this is addressed in the LabVIEW build specification for your application.
4. I would worry about it, I can't find any real documentation on it. I don't think it will hurt you.
5. Not sure about this one, I have no problem switching Tabs without saving. But if it makes you save, I guess you have to.
6. You should have no problems with your IVI drivers in LabVIEW 8.5 as long as they are not from before LabVIEW 4.
7. What can I say, National Instruments is a global company.
Good luck, and you may get quicker responses when you only ask one or two questions per thread at a time.
01-15-2008 02:17 PM
1. I see that the rest of the world has moved on and that I am in the middle of the IVI timeline. Which version of IVI am I using, according to IVI.org?
Both ICP 2.3 and 3.2 (the current version) are compliant with the current IVI Class Specifications.
Taken from the ICP 2.3 Readme”
“IVI Compliance Package 2.3 installs the following components:
All IVI drivers need the shared components, so that is the most important version number. However, I strongly recommend that you upgrade to ICP 3.2, which includes IVI Shared Components, version 1.5.0. The official IVI website is ivifoundation.org. You can find all of the specification documents there.
2. I need to deploy the test to the far reaches. I know that I can just copy the configuration store XML but I will need a tool to mix-in new apps in the future. Does this tool exist? In LabVIEW?
This tool does not exist, see the
response to question 3 for information on deployment.
3. What can I get away with in a
deployment? Can I just copy dlls to the IVI\bin file and modify the XML or do I
have to make installers that call installers?
What we recommend for deploying your IVI system:
A. Make an installer in LV that includes the current versions of MAX, VISA, ICP, NI-488.2 and of course the LV RTE
B. Create another installer that first calls the installer that you made in LV, and then calls the IVI specific driver installers. You do this so that the specific drivers are registered correctly. This installer can also install the copied IVI ConfigStore XML, so you won’t have to re-do the logical names and other settings.
C.
Create a set of instructions that tell your end user how to discover the
Ethernet Scopes in MAX and create VISA aliases for them.
01-15-2008 02:17 PM
Found at: http://www.ivifoundation.org/docs/IVI-5.0_Glossary_v1.01.pdf
The
Repeated Capability Name is: The name published
by an IVI driver or class specification to refer to a particular
repeated capability. For example, the IviScope class specification defines “Channel”
as a repeated capability name.
5. In MAX, do I really have to "Save
IVI Configuration" before switching tabs in MAX? It seems like I do.
That is not the behavior that I am seeing in MAX 4.3 with ICP 3.2. Saving the IVI configuration saves the IVI Configuration Store XML file, so you should save it whenever you want changes made to that XML file, which the class drivers then use to get configuration information from. Upgrading MAX and ICP should resolve that issue.
6. Will these IVI driver dlls break with LabVIEW 8.5 and all it's associated stuff (VISA, MAX etc.)
The DLLs
will not cause problems, BUT ICP 2.3 does not include support for LabVIEW 8.5,
which is another reason to upgrade to ICP 3.2.
If you install LabVIEW 8.5 on your current system and open your
application in LabVIEW 8.5, it would be missing all of the IVI VIs. The same thing would happen if you had a VISA
application and had not yet installed the version of VISA that supports LabVIEW
8.5.
7. I see the knowledgebase article about
configuring MAX. Is this available in every spoken language?
Many of our Knowledgebase Articles have been translated into multiple languages, but just because you can find one Article that has been translated into one language does not mean that it has necessarily translated into other languages. It would be great to have all of our content translated into every spoken language, but I don’t think that we have the resources for that.
Cheers,
NathanT
