acquire data from oscilloscope
Hi everyone,
I want to acquire data from an oscilloscope. I have written a .vi to do it. I am using a NI 9207 and the oscilloscope is an old device A-F Oscillator Marconi Instruments.
I have configured the DAQmx setting the channel in continuous sampling with sampling rate 10000Hz and sample to read 1k.
When I run the vi using the DAQmx, the signal looks a pretty good sinusoide. When I use the same vi to acquire data from the oscilloscope the signal appears not sinusoidal but a mix of square signal. I think there are problems about sampling but the parameters used to set the DAQmx are the same.
I have attached the .vi
Anyone has an idea of what it is happening?
Mato mato
(3,957 Views)
Hi mato
Your acquisition loop has not got any timing in and so will be iterating as fast as it can; however there is a nondeterministic element in the loop the front panel updating in the form of the wave form chart.
I would recommend looking at the producer and consumer architecture.
This can be found in file >> new >> VI >> from template>> Frameworks >> design Patterns >> Producer / consumer Design Pattern (Data). This is a method of keeping deterministic and non deterministic code separate.
How are you interfacing the 9207 with the oscilloscope?
Regards
Robert
National Instruments UK & Ireland
(3,933 Views)
Hi Robert
Thanks for your reply.  Sorry but can you explain better what is about the producer/consumer data difference?
Anyway, back to my problem, I am using a signal generator to generate a sinewave of 10 Hz.
The output from the signal generator goes to the oscilloscope to see the wave and the NI 9207.  Moreover, I have connected the  AI+ and the AI - from the sign. gen. to the pin 1 and 20 of the NI-cDAQ and a resistor of 1MOhm between the pin 9 (COM) and the AI - to acquire differential data.
After that, I have opened a panel test for the channel chosen for the acquisition. Setting "On demand" it looks to acquire well at low frequencies while the acquired data assume a strange shape at higher frequencies (maybe there is a aliasing problem), see figure 8. When I set "continuous sampling" I see a square wave.
Successively, I open a new task to set up the acquisition data. I put the device in High speed mode and in continuous sampling. It looks ok, see figure 9,  and following well the signal generated by the external signal generator. I save this channel and then I open my VI using it. Still I have a square wave, see figure 12.   😞
What should be wrong?
I have checked if the DAQ is ok by acquiring a DC voltage from a simple battery and it looks ok moving the DAQ in all the slots of the NI-cDAQ. I also measured the volt difference between the COM of the DAQ and the ground of the signal generator and it is around +/- 3Volts.  I don't know what is wrong or what I missed!!!!
(3,930 Views)
Image12 shows that you are ignoring the answer here and using a sample rate that is not supported. Why?
(3,918 Views)
Hi Dannis
sorry you're right... I didn't change this parameter.
matomato
(3,913 Views)
