activex implementation problem
i posted this in the software forum but i think it makes more sense here
i have a liquid dispensing system mounted on an xy stage and being imaged by a camera. the dispensed liquid is also measured using a weighing module in real time. The XY stage doest not have direct drivers for labview and so i have to operate it through active x commands. this is the first time i am using active x.
When i run the vi I ideally i should see the webcame image and the change in weight continuosly. However both of these freeze the moment the activex controls are activated and the stage begins to move. The stage is supposed to move to different positions and only when it gets to those positions the webcam image and the weight graph get updated. Once the activex is stopped at the end of movement ( vi is still active) i start getting continous data on front panel for wecam and weight.
I hope I have explained my problem clearly. I want the front panel to show continous accquistion and not freeze everytime the xy stage moves. I might be programming it incorrectly so I have attached the vi. i am using labiew 2009.
Thanks for your help in advance.
(3,412 Views)
duplicate post
Please stop creating multiple posts asking the same question in multiple places. That is very annoying and counter-productive.
(3,398 Views)
