agilent 34405A AC-volt measurement.
I have a agilent 34405A Multimeter from which I want to capture AC-volt measurement data.
I have created a simple vi which works for DC-volt but doesn't for AC-volt.
I get an error:
Error -1074118123 occurred at IviDmm IVI Error Converter.vi
Possible reason(s):
Agilent34405: IO timeout error: VISA error = Could not perform operation because of I/O error..
Complete call chain:
     IviDmm Configure Measurement.vi
     agilent.vi
Does anyone know what I do wrong?
thanks in advance,
arjen
(3,451 Views)
Hello Arjen,
       There is a great document that you should take a look at: Instrument Driver Troubleshooting Guide.  If you are not already, you can also try theIVI-C instrument driver for your device.
       After you have gone through the steps of the troubleshooting guide, please let us know if you are still seeing the problem.
Cheers,
NathanT
(3,434 Views)
