agilent 81110a pattern generation
I am new to programming instruments and I have been tasked to
programming a pattern into the 81110a. The documentation is a little
hard to follow. Basically I need to program a repeating pattern of
pulses at 50 Hz. any help will be appreciated. Can I set the rate that
low?
Mike
(3,350 Views)
Hi Mike,
I searched our instrument driver network at ni.com/idnet, and we do have an instrument driver for the 81110a. I am not familiar with the 81110a, but the instrument driver would be a good place to start, and I'll suggest you give it a shot.
Hope this helps. Good Luck!
Ebele O.
(3,331 Views)
