agilent current level
Hi
I got a Agilent E3648 Power supply, I need a program to control the current values, so within the driver there are some examples but just for voltage level and since I  am using the device as a current source I cant find a solution. Please there is another driver that has this kind of examples? I'll apreciate any help! thanks guys!
I am able to make a program that controls the level of the output voltage. my goal is to do the same but with  current!
(4,377 Views)
Study the manual. If it can be set as a current source, find the commands to do so. You can search the driver for those commands. There may not be a specific example. You can also open Context Help to view the description of each driver function and see what each does.
(4,367 Views)
