agilent mixed signal osc
hello,
i'm trying to develop a driver for the Agilent MSO6034A oscilloscope: it must be able to acquire a screenshot, load a preset stored on the computer and save a preset from the osc's memory to computer.I'm currently using the GPIB port but i can use also USB.
I had downloaded the latest driver here and i also have installed agilent I/O software suite.
The problem encountered is when i send a command to the Osc, the command is often ignored,works sometimes and error messages like "query unterminated" and "header error" are reported.
Errors happen when i use the supplied driver, the agilent I/O softwares and commands sent simply via labview.
So i don't know where the problem comes from...the driver?Agilent VISA?conflict between NI visa and agi Visa?osc?computer?
thanks to anyone who will reply..
(3,179 Views)
Hello train33,
        Which Instrument Driver are you using?  We have a Project-Style LabVIEW Plug and Play Instrument Driver here.  The errors that the instrument is returning are usually a result of incorrect commands being passed to the instrument or the commands not having the proper termination character.  If I were in your same situation, I would just use NI-VISA, recognize the MSO in MAX, and use the LabVIEW Plug and Play Instrument Driver that I linked to.
Cheers,
NathanT
(3,166 Views)
