aquerir from dsp
hello  Smiley Wink
PLEASE I have a DSP (TMS320C6711) and I want to visualize a word signal  treated  by this DSP, under LABVIEW 8.0 or 7.1 through the parallel port but the driver of this DSP I do not have it, for that I wanted to use the assistant io instrument, this last when I make it draw it appeares a message saying that it is not correctly installing .
in end if any one has a solution contact me and thank you
Message Edité par fethy le 04-05-2006 09:15 AM
(3,346 Views)
Fethy,
See if the suggestions in this KnowledgeBase help.
Robert Mortensen
Software Engineer
(3,336 Views)
