are any drivers available to integrate HPLCs from Spinco Biotech with labVIEW
Dear NI,
The Instruments Iam looking at are HPLCs and Gas Chromatographs from the below mentioned vendors.Kindly let men know if any more details are required.
The instrument models what Iam looking at are as follows.
Manufacturer
Model Number
Description
Shimadzu
SPDM20A
UV Visible detector
SL20ACHT
Auto injector
CBM20A
LC20AT
SIL-10ADVP
auto injector
CDD10AVP
detector
R1010A
detector
LC 2010A
Chromatographic system
Young Lin Instruments Co Limited
YP9111
Binary gradient HPLC Pump
YL9160
PDA detector
YL9150
HPLC auto sampler
(3,438 Views)
Talk to the instrument manufacturer about use if possible with LabVIEW.
(3,436 Views)
All of the drivers that NI has are listed here. There are only a few for Shimazdu and only balances. None for the other vendor. In order to control with LabVIEW (or any other programming language), the instrument must have a remote control connection that you can connect to the pc and a published specification for that remote control. As mentioned by nyc, you need to start with the vendor.
(3,431 Views)
