auto port configuration
i have a problem in configuring the auto port configuration . As due to my program there is more than one aplication so there will be more than 1 port used but the visa configure serial port only allow to have one COM input selection at a time. i am thinking is it posible to have all the possible COMs available to loop one by one on its own ...
(3,973 Views)
Not sure what programming language you have, but I'm sure whatever it is, there is a loop function. You can get an array of VISA resources with the VISA Find Resource function.
(3,959 Views)
thanks for the reply ...
i am using labview 8.5 and i can get the source from visa find resource but the output array can only be view i don know how to extrate the value and also the visa serial can only connect to the visa resourse name and can only select one source at a time . wad i wan is to have a loop to continueously input the source one by one without manual slection ... thanks alot if it can be solved ...
(3,919 Views)
If you wire the array of resources through a for loop, the for loop will auto-index the array. That's LabVIEW basics. Place your code inside the for loop to sequentially do what ever you want.
(3,911 Views)
