board Hameg HO-80
my board isn,t reconize on max and i,m looking for how to do.
the board is designed on a nec 7210 chip
thank you for your help
(3,190 Views)
Similar questions come up all of the time about non-NI boards. MAX is a utility program designed only for National Instrument boards. It should not be expected to detect and control non-NI boards. There are some exceptions but you shouldn't count on it. To configure, test and use your board, you should use the software from the vendor.
(3,187 Views)
