buffering recieve data from serial port
thanks
that guide actually solve most of my problems.
Message 11 of 16
(1,889 Views)
thanks for replaying hatef.
i think im gonna do this and put some key on labview for starting send/recieve data.
Message 12 of 16
(1,888 Views)
dear
after ploting data on waveform chart,the process of recieving data and plot it takes long about 6 or 7 minute,how could i see all of the data on the chart?
because i cant scroll the chart and only i see the last 10sec data.
and what can i do for time axis to shown in ms?
and how should i export all of the data (full chart) to image?(when i export it only the last 10 sec will be shown)
thanks
Message 13 of 16
(1,878 Views)
1. You can change the length of the history for the chart.  If you want 10 minutes worth, that would be 10*60*1000 = 600,000 samples.
2. You can right-click on the chart and change the x-axis scale
3. You can right-click on the chart and choose to export to an image.  If you want a limited amount of data in the image, then you will want to change your scale first.
Message 14 of 16
(1,872 Views)
for last question:
my result have noise floor and some peaks
there is way to calculate the area of peaks?
something like integrator?
and could i see the time that peaks happen?
thanks alot
Message 15 of 16
(1,864 Views)
In the Signal Processing->Signal Operation palette is a VI called Peak Detection.  I don't think it gives the integral, but it does give the amplitude and location for you.
Message 16 of 16
(1,861 Views)
