cRIO-9067 and GPIB-ENET/1000
I have a cRIO-9067 and a GPIB-ENET/1000 that I am attempting to interface together.  I installed the NI-488.2 drivers on my host computer and can communicate with the GPIB-ENET/1000.  I am now trying to add the GPIB interface to the cRIO under "Network Devices," but I am unable to install the software drivers to the cRIO.  Is it possible to install the NI-488.2 drivers to the cRIO and add a networked device?  If not, are there any other suggestions to getting the hardware to interface together?
Thank you very much for your help.  It is greatly appreciated.
(3,733 Views)
Accepted by topic author gkraus
gkraus, no you will not be able to install 488.2 on your Linux-RT cRIO, because GPIB is not supported on the Linux RT OS (https://www.ni.com/en/support/documentation/compatibility/17/ni-visa-features-and-operating-system-c...)   However, you can use the GPIB-RS232 to interface with the GPIB instrument(s) via a serial port on the cRIO.
Clemens | Technical Support Engineer | National Instruments
(3,669 Views)
Is this still true? According to the link, the NI Linux RT OS is supported.
I have a GPIB-ENET/100 device that I would like to use with a cRIO-9039
(2,496 Views)
Pose your own question to the forum under a different thread.  I don't care to get updates on issues that were resolved years ago.
(2,490 Views)
Thanks, you've been a HUGE... help.
(2,479 Views)
