cRIO & NI 9871 RS485
I am using cRIO and 9871 (RS485 module) for communicating with a device using MODBUS protocol. I have converted the Full Duplex interface of 9871 into a Half Duplex interface using a small custom proto cable (see attached schematic). Also I want to check the communication with the device over a distance of 1000 feet. As I do not have 1000 feet of cable so I am using a resistior to simulate the 1000 feet lenght for the following cable specs
AWG - 22, Cable resistance / 1000 feet = 16 Ohms
When I remove this resistor from the line I am able to talk with the device successfully, but when I insert this simulator in the line even though I get a 2V peak-peak differential signal at the input of 9871 I am unable to establish communication between 9871 & my device.
Please let me know what could be a possible solution to this problem.
Vikas
(5,761 Views)
Vikas
Since you are still getting a 2V Peak to peak value the signal is not being attenuated linearly, but the resister will make changes in the high frequency latency. I would recommend taking a high frequency oscope capture of the signal with and without the resister, we should be able to see a clear difference that is making the signal harder to read. My guess is we may see longer rise time which maybe skewing the data. Let me know what happens
Hunter
(5,718 Views)
Thanks Hunter. I tried the loopback test on the same channel with 16 Ohm resistors in the line and it worked. I also tried full duplex communication between two channels of NI9871 with 16 Ohm resistors in line and that too worked.
Also when I use a RS232-RS485 converter and test communciation between a PC & other device, it works without any problems even with 16 Ohm resistors in line.
But this thing does not work between NI9871 & the other device.
Can you suggest what could be possibly wrong.
Regards
Vikas
(5,692 Views)
I am using a 9871 on a sbRIO board and I will use it to communicate to a temperature controller which uses half-duplex mode. I have not been able to get communication with the instrument and I think it is related to this. Is there a good Knowledge Base on using the 9871 in Half-Duplex mode?
Wait a minute, is half-duplex another way of saying two wire? If so, I have already jumpered TxD+ and RxD+, etc. This is what I have done with all my NI serial devices. I thought that maybe my problem was with the TC instrument requiring <stx> and <etx> characters wrapped around all ASCII command strings. I wonder how this works when its converted to a byte array and sent through the FPGA.
Doug Ferguson
(5,044 Views)
Never mind, I figured it out. The wires weren't even connected to the temp controller.  Smiley Very Happy
Doug Ferguson
(5,015 Views)
