can CVI be interfaced with a standard A/D converter?
i want my CVI to drive a ckt having motors. so is it possible to interface my CVI with standard A/D card or i require any other boards from NI for the same
(3,227 Views)
Yes it is possible. If the Card is National Instruments DAQ card, then you can find the NI DAQ functions by going to Library>>Data Acquisition. If you have a third party card, then you will have the access the card driver using C calls.
By the way, this posting is in the serial discussion forum, when it really belongs in the LabWindows/CVI forum.
(3,227 Views)
thanks for your kind reply. your answer very much satisfies my question
(3,227 Views)
