can not rename the visa resource name
I use the keithley DMM 2110, connected to PC via USB. There is an error when I try to rename the VISA resource name. What does the error code mean? Any advice would be greatly appreciated.
(4,722 Views)
Using Kiethley devices with NI-VISA drivers will only work with LabVIEW 32-bit versions and you had to install the 32-bit
 I think that the driver wasn't installed properly in your computer and I would advise you to reinstall the driver correctly once again.
To achieve that, you will need to:
1) Repair/Unistall the NI-VISA from your computer
Go to this link: http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D?OpenDocument
2) Install the NI-VISA from a CD/DVD that you might have or you can do it from the NI website
Go to this link: http://www.ni.com/download/ni-visa-5.4.1/4626/en/`
Note: Use NI Downloader to download the software. since it is stated to be the recommended tool for downloading NI Software.
(4,691 Views)
