can't load core essentials during install of Labview 7.1 when 7.0 is already loaded
I have 6i installed and I also loaded 7.0 student version with no problem.But when I load the 7.1 upgrade CD it gives me errors during the install steps.(ie can't load core essentials). I am running xp with service pack 2 .Any sugestions will be helpful
(2,910 Views)
Can you attach a screenshot of the error message you receive?  You could try to unintall your 7.0 student addition, and then install 7.1, but in general there is no problem having multiple versions of LabVIEW (such as 7.0 and 7.1 in your case) on the same machine.  In the very worst case, I think uninstalling your current NI software and then installing 7.1 should work, but I haven't had problems with multiple versions on the same machine (although perhaps there is a quirk with the student edition, but that is pure speculation at this point).
I hope you're able to get 7.1 installed soon!
Best Regards,
JLS
Best,
JLS
Sixclear
(2,896 Views)
