can text and convert dec to binary
i am trying to convert the text file numbers (dec) into binary
and use those values to decode it.
can someone help me..
i am facing some issues because its 2d array?
can someone help me one this..
Message 1 of 8
(4,517 Views)
Convert to binary text? Or a numeric. Assuming LabVIEW, with a numeric, you can just change the display options.
'facing issues' is extremely vague. Details.
What 2D array are you talking about?
Why did you post to this board?
Message 2 of 8
(4,509 Views)
sorry, i was looking at this forum for VISA and usb and i forgot to change it before I post the questions.
i have the results.txt.
I just want to convert those string to numeric to binary numbers.
i tried it by doing this..but I was getting a 2D array instead of 1D array like the text file.
Is there a reason why?
Message 3 of 8
(4,498 Views)
Accepted by topic author Giangliang
The All Rows output of Read From Spreadsheet is supposed to be a 2D array. You just need to use the Index Array function to get column 0.
Look at the attached modification.
Message 4 of 8
(4,495 Views)
whoa...your vi works on 8.5
but i tried the same on another computer running 7.0 and i didnt get the binary numbers, i only got the decimal number?
Message 5 of 8
(4,491 Views)
It would if you had used my VI in 7.0 or if you had set the format & Precision for binary display
Message 6 of 8
(4,480 Views)
oh..i didnt know that..
that works...
hmm..
sorry to borther with your time..
but the reason why i am donig this because i want to use those values in this form.
how would i transpose it to
that form? in a continous fashion instead of one frame at a time.
i also want to count the number of bits when the numbers are converted to binary.
i think it should come out to be something like 1728 bits...
i hope it is because its what i am looking for..i have never worked with binary and bits before in labview so i am very lost in this sense.
Message Edited by Giangliang on 04-02-2009 04:28 PM
Message 7 of 8
(4,478 Views)
i got this...
but I am not sure its right..
it has enough bits, i think..
but i am not sure unless i put the bits in the order as indicated above..
Message 8 of 8
(4,464 Views)
