chroma 66202 driver installation
So i tried to install the Chroma 66202 and it said that its successfully installed it. So i followed these steps b: http://digital.ni.com/public.nsf/allkb/86256F0E001DA9FD86256F0B0057E6E7 but it still doesnt work. I thought maybe the problem would be that the driver is meant for a 32bit computer and me having a 64 bit computer. Is this the problem or i am doing something else wrong?
attachments are the steps that i took 1) install 2) copy and paste to 3)
(4,938 Views)
The driver is there as you included in the second screen shot.  It is a non-certified driver and does not include a LabVIEW wrapper.
(4,901 Views)
Accepted by topic author n223berekeley
As mentioned, there is no LabVIEW adpator for this driver. As you can see on the download page you can only use it with LabWindows/CVI or Measurement Studio.
You can convert this driver from LabWindows/CVI to LabVIEW using the following DeveloperZone tutorial.
Good luck.
Jacob R. | Applications Engineer | National Instruments
(4,886 Views)
Thank you so much!
(4,870 Views)
