code error -1073807339 ethernet
I ried your command but still not work. So why I still have the same code error  ?
thanks
Message 11 of 15
(1,654 Views)
The manual is not much help. You can try putting a space after the question mark. My guess is that the syntax would be the same as the FETCH:FIELD query. Did that query work? Are there any programming examples that came with the instrument? What about asking the instrument maker to clarify the query?
Message 12 of 15
(1,648 Views)
I tried FETCH:FIELD query. It didn't work.  I tried putting a space after the question mark without any results.
Here another programming manuel of the same familly..
Message 13 of 15
(1,638 Views)
I don't knwo what else to try. You should contact the isntrument vendor.
The syntax for a fetch as defined by SCPI is :
FETCh[:<function>]? <parameters>[,<source list>]
Parameters are allowed in the FETCh? query. They may be defaulted from the right by
omitting them, or in any other position by substituting the keyword DEFault. DEFault must
be accepted as a parameter for this query. If a parameter is specified, it is used in the
calculation if applicable. If the parameter is invalid because it conflicts with the acquired
data, an error -221 shall be generated. If the instrument receives a parameter which is
unexpected (too many parameters), it shall process the query and return the data. The
unexpected parameter shall be ignored, and the “command warning” bit of the “data
QUEStionable” status register shall be set.
PH018
A special parameter type is the <source list>. The <source list> is syntactically a <channel
list> as described in “Syntax and Style.” The purpose of the <source list> is to specify the
physical port which is the source of the measurement. For example, (@2) would specify that
the measurement should occur on channel 2. Multiple channels can be specified by using
multiple channels in the channel list. For example, (@1,3:5,9) specifies that measurements
are to be taken on channels 1,3,4,5, and 9. SCPI does not specify if the acquisitions are
simultaneous or sequential. A function which requires multiple channels, such as time
interval, would specify each channel as a separate list. For example, (@1),(@2) would
specify a two-channel measurement between channels 1 and 2. A multiple channel, multiple
measurement is specified by using multiple channels in each of the lists. For example,
(@1,2),(@3,4) specifies a pair of two-channel measurements, the first between channels 1
and 3 and the second between channels 2 and 4.
Message 14 of 15
(1,623 Views)
I've been very busy the past 2 days but in reading what Dennis has said I can only agree with him.
The initial manual to any instrument is a brief summary of each section/command.  Before releasing the entire manual they breakdown documents of each section.  By contacting the instrument provider and questioning a precise area, in your case the FETCH? query, they can send the documents pertaining to that one section.  Most of the time they are outdated but contain very minor, yet helpful, things they didn't feel necessary to include in the main manual.
Through my own experiences I've at times received articles written on the instrument, numerous documents pertaining to my area of interest, sample data from successful runs that they received through testing, and hard calculations that are executed through the instrument.
Best of luck Smiley Very Happy
Message 15 of 15
(1,616 Views)
