communicating using a USB to serial cable
I am new with labveiw and I need to interface with a Network Analyser. But my laptop does not have a serial port. I was thinking about using a USB to serial connecting cable for this purpose.
Do you think i would still be able to retrieve readings through it?
(3,821 Views)
Hi
A good usb to serial converter should look and act as if it was a built in com port.
greetings from the Netherlands
(3,807 Views)
Amy_21,
I use USB to RS232 and RS485 serial converters every day.  I have had very good luck with converters from National Instruments, B&B Electronics and Black Box.
(3,793 Views)
I use an Amplicon USB converter as it will use the next avaiable comport and not a silly comport number like most addapters do.
NI Serial Card (not usb converters) are inconsistant and somtimes give you a reversed order of high number comports. (8 port card)
Colin
(3,707 Views)
