communication with Prologix in LabWindows/CVI
I have an Agilent 33220A connected to a PC using the prologix usb controller. I can talk to the instrument using Hyperterminal on com port 3. When I open Measurement and Automation, under ports the controller is seen as ASRL3::INSTR.
I have tried to use the control test panel to send *IDN?\n in viWrite and query it using viRead and I get a 0xBFFF0015 error. I also just tried to send *TST? and there is no action on the instrument.
I also tried using the RS232 write function for COM3 and still cannot talk to the instrument.
Is the format of the commands the problem or is there another interface I need to use?
(6,897 Views)
Hi Brdman,
Could you please perform an NI-Spy capture and upload the capture log file here? This would make it easier to troubleshoot. There are very good instructions on how you can do that here.
Rasheel
(6,881 Views)
Sorry for the delay. Here is the data from NiSpy
1.  viOpenDefaultRM (0x00DE4E20)
Process ID: 0x000001D4         Thread ID: 0x0000035C
Start Time: 09:23:35.781       Call Duration: 00:00:00.078
Status: 0 (VI_SUCCESS)
2.  viOpen (0x00DE4E20, "ASRL3::INSTR", 4, 0, 0x00DF7E48)
Start Time: 09:23:36.171       Call Duration: 00:00:00.125
3.  viGetAttribute (0x00DF7E48, INTF_TYPE, 4)
Start Time: 09:23:36.296       Call Duration: 00:00:00.000
4.  viGetAttribute (0x00DF7E48, RSRC_NAME, "ASRL3::INSTR")
5.  viWrite (0x00DF7E48, "*IDN?.", 6, 6)
Start Time: 09:23:41.406       Call Duration: 00:00:00.015
> 6.  viRead (0x00DF7E48, 0x00DF9E08, 1024, 0)
> Start Time: 09:23:44.375       Call Duration: 00:00:02.000
> Status: 0xBFFF0015 (VI_ERROR_TMO)
(6,847 Views)
Hi Brdman,
Could you  please upload the .spy file itself? This will make it easier for me to track down what's going on. Thanks!
Rasheel
(6,834 Views)
Here is the SPY file.
(6,829 Views)
There is thread where someone is using the same controller with LabVIEW and an example program from Prologix appends a CR/LF to each command. You are appending only a LF.
(6,824 Views)
Thanks Dennis for the input. I was able to get a 34401 DMM to communicate. I am not real familiar with using VI commands but was able to get it working by using the following commands
viOpenDefaultRM (&dmm);
viOpen (dmm, "ASRL3::INSTR", VI_NULL, VI_NULL, &dmm22);
viWrite (dmm22, "++addr22\r\n", 10, ct); //assign prologix address to instrument
viWrite (dmm22, "*IDN?\r\n", 7, ct); //query instrument
viRead (dmm22, read, 100, ct); //read back query
viWrite (dmm22, "*TST?\r\n", 7, ct); //selftest instrument
(6,745 Views)
