compact rio rs232
Hello, we are 3 students of engineering at the University of Palermo.We have to acquire an analog signal and use the rs232 port on the chassis of a compact rio 9014 to send data to another device that acquires signals through serial port.Can we use the serial port as output of the compact rio 9014 and pick up a signal?
Thank you
(3,443 Views)
Hello Guys!
You can refer to the following example in order to have your cRIO communicate through Serial Port:
Serial Data Transfer Between cRIO and Host
Let me know if it works or if you need additional help.
Best regards
Related Links:
What is the Maximum Baud Rate for the Serial Port on the CompactRIO Controllers?
Matteo
(3,434 Views)
