Hello!
I need to connect a relay card to an array of Booleans to connect each relay, that is, I want to replace, in some way, the VISA read and the VISA write by the Boolean array, so that without writing the relay number you can connect in an order with the same while and for structure.
I hope you can help me.
Thank you!
