connect and aquire signal from renishaw TP8 probe
Hi everybody,
as part of my system I have toutch probe (TP8 from Renishaw) with PI 200-3 interface which supplies power and controls the operation of the probe
The TP8 / PI200 is a standalone system. The TP8 probe is essentially a normally closed switch and the PI200 conditions this signal.
I would like to use the SSR output from the PI200 so the only input to the Labview software is a pair of normally closed contacts.
how can I connect and aquire the signals from the TP8 probe when trigger event occurs.
any help in getting started would be appreciated.
thank you,
Message 1 of 1
(3,116 Views)
